coolktm
37
Anyone know what the wear limit would be? I have a 97 250exc. I am having brake problems and my last(and most expensive) idea is to replace the disc.
Danman
2,208
Is it not stamped on the disk? If not the factory manual should tall you. I just replaced my front and it had 3mm Min stamped on it.
coolktm
37
I will have to check and see if it says the limit. Any ideas on what symtoms a worn disc will have? Is it just decreased stopping power?
RAH RAH
305
thats a good question your bringing up. i just bought a braking rotor and it says 2.5mm. fresh pads and proper bleeding really make a difference. as does front wheel bearings. I dont know what signs a wore out master cylinder gives but someone around here should.
I would freshen up all the little things before moving to the big ones.
good luck
