TheDnis
i just replaced my dust seals and oil seals in my front forks... and they didnt last very long at all. I have heard that after the originals go out that nothing will last very long, so i need advice as to what to buy with seals... factory oem or aftermarket? or should i buy new shocks? any advice is welcomed, thanks
mandark1967
246
When I rebuild forks, I replace dust seal, oil seal, AND the bushings...Also be sure that the seals are properly seated (they can be a PITA sometimes)
Additionally, closely examine your sliders while your forks are apart to ensure there are no nicks in them.
TheDnis
hey thanks but why are the bushings important to replace with the seals? is somewhat true that seals wont last very long after the stock ones blow? or is that a myth that comes with a bad rebuild job?
KaBooM
21
What really happens is when the fork deflects the bushing and seal take the hit, like a pivot point if you will. This is a big issue of why OEM seals and lower DU bushings do not last and wear down quickly.
The alternative to OEM would be Synergy Seals. They come with a backup ring which sets in between the seal and snap ring. This backup ring protects the seal and the DU bushing during the forks deflection, and most important, it keeps the seal axially straight!!
Good luck, Rob
IndyMX
Crash Test Dummy
5,548
Amo, IN
It's probably more so a bad rebuild that caused them to fail prematurely.
