Hey everyone! I just had my '98 YZ 125 engine rebuilt by Eric Gorr and bored and ported it to a 135. I also purchased a V-Force3 Reed Valve to put on the engine once completed. I totally cleaned the carb while the bike was apart replacing all gaskets and vent lines.
The bike is back together and I have taken it to the track the last three weekends. The bike runs great, however, everytime I ride now, when I stop and get off the bike, fuel leaks out of the hose attached to the bottom of the float bowl. I routed the vent lines the only way I know how and it does not seem to make much difference. This happens almost after every session, and when it does a large amount of fuel leaks out. It is not a constant stream, but it is certainly enough to be weary of I think. After a few minutes the leaking stops and everything is okay again. It seems to happen more if I kinda shake the bike. The only changes to the bike are those mentioned above. What am I overlooking?
Any thoughts or suggestions will be greatly appreciated.
Brady
Brady
