steve125
- Oct 19, 2000
- 1,252
- 0
Oh boy did I just hava a scare!! :scream: All is well for now but? I just started using U4 in my new kxf250. After some jetting the fuel works just great. My problem was this morning went out to work on the bike and noticed the hot start lever wouldn't pull in. Everything checks ok lever, cable, seems the fresh air piston was stuck inside the carb bore :scream: After alot of wd40 and some air pressure and finally a hard pull, it popped out of the carb. It was working fine the day before so what happened? There was a slight corrosion spot in the carb bore and on the brass piston. Cleaned it all up with some 600 paper and for now all is well. My first thought could it be the U4??? or was it just one of those mystery things?
Rich is it possible the U4 is responsible in any way? :think:
Thanks Steve
Thanks Steve
