gas and spark, but no fire, what next ?
cleopatrisha
86
I own a 1981 yz250 It gets fuel to the spark plug and has good spark but it won't fire or start. what should I check next? and how do I check my timing?
cleopatrisha
86
Mouse nest
It does have plenty of compression, but upon further investigation I found a mouse nest inside my expansion chamber. which I cleaned out. I did get it to run but with ether (aka starting fluid) sprayed directly into carb . but I could not get it to start or fire on the gas from the tank which is fresh mix.
76GMC1500
Uhhh...
If it runs on ether but not without, you're not getting fuel. Open up the carb and really clean it. Remove the jets and blow them out. Blow out all air passages. How plugged is the air filter?
cleopatrisha
86
Air filter was taken off prior to starting.
I should also point out as it ran on ether it ran a very high rpm is this normal when you spray ether directly into carb.
Bunya
147
Yes, because there's nothng metering it. Keep in mind that when running on either the motor isn't getting any lubrication :yikes:. Follow GMC's advice and clean the carb thoroughly. Also be sure your air filter is clean and freshly oiled before taking it out for a ride.
cleopatrisha
86
Thanks for all comments
I cleaned the carb well accually I had my lawnmower repairman friend help me and it runs great now he also adjusted the float. the carb definitaltly needed cleaning. again thanks.
