The Honda Pilot
- Feb 25, 2001
- 394
- 1
I need your assistance. At TNT I have a problem with a jump there I beleive I have heard people call it the " ant Hill " because it has a tank under it. Anywho its the jump following the whoops that you double through than after the small double around the next corner its like a table top ? anywho on my 125 I hit it in 3rd gear preety fast and from what I know your front wheel always leaves the ground atleast 2 feet before the actual top of the jump. So when I hit this jump due to the front wheel comming off the jump sooner than the rear I land up going vertical. Is this caused by me hitting it with to much speed ? I have seen some guys come burling out of the corner and slow down for it than blip the throttle on the face and clear it just fine....now me on the other hand I hammer it out of the corner like everyone else then keep it steady 3/4 throttle in 3rd gear up till the face then I let off and blip it one good time on the face and I go vertical. I try body english and tapping the rear brake and holding it but yet it never gets my front end down as far as I would like it . I would love to hit it just fine needing no adjustments any suggestions ? Should I take it slower and then hit it wide open on the face of the jump or take it steady down the straight then blip it on the face ? i think speed is whats killing me I also over jump it BAD 2 out of 4 times....and bottom HARD ! any help would be great.
