MuleWrangler
- May 25, 2008
- 1
- 0
I just got a Yamaha GT-80 in good condition (except it was a yellow-clay dirty mess) but am having some issues I need help with. I have ordered a manual but it is not here yet. :(
My questions:
1) What oil/fluid do I put in the gearbox (filler by the kickstart)? I did a search and saw someone said 10W40, but I am not sure about that.
2) What oil do I use in the oiler tank (that mixes with the gas)?
3) What is the shift pattern on this little guy? A search shows four down and neutral is up? I can't figure it out due to the below issue...
4) The rear wheel keeps locking--I put it into neutral (as far as I can tell) and start to roll it, the gear shift clicks and the rear wheel locks up. The gearbox fluid is very low--could this be the issue? It also does not seem to shift into all of the gears.
Thank you so much in advance!
My questions:
