Kav
Crash Master
1,516
I just pick up a new Philips 30" wide screen HDTV and an APEX Progressive Scan DVD Player. MOst evey thing is good to go but for what ever resion when I hook up the composit video from the DVD player to the tv al I ger is garbage on the TV. acording to the instructions for both I have every thing set up right, but nothing seems to work. All the other A/V imputs on the tv and A/V outputs on the DVD plater work right though. Any ideas?
JWW
2,527
Before I hooked up our dvd player I had to set the display for component cables before actually plugging them in.
Is it possibe that you have a couple cables crossed?
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Some players have switch settings in the back for what type of connections you are using, be they coaxial, optical, etc... you may check that.
Your Phillips, it is a reciever too I assume, and not just a monitor?
Kav
Crash Master
1,516
All the cables checked good, and the TV and the DVD player were set up right (according to the instructions) and still no dice. :(
I did recheck th eback of the TV and there aren't and switches
Jaybird: it is reciever too
gnarlykaw
986
clear the TV settings. then reprogram the TV again with everthing plugged in and powered up. MOST of the new big screens need to "ident" the ports as you set up the inputs. make sure you dont have two devices on the same input.
