Ok as some of you know my 1991 Honda XR250R is burning oil, Taking tomorrow to fix, Well today I went out and Wondered if my valves were heavily carboned and were opening, Well I knew the intake valves were atleast opening because it is still running so its getting air,fuel into the cylinder, So since the XR250R's have 2 header pipes(1 for each exhaust valve)I wondered if they were opening and everything, I know I wouldn't have known if they were to loose or to tight but just making sure they were atleast opening, So I started the bike and let it idle for about 4 to 5 minutes, And while the bike was still running I reached down and touched the left header pipe, it made my finger sting so it was "HOT", Then I touched the right header pipe and I could hold onto it and it would not burn me, It was still pretty cold to the touch, Should I stop riding the bike? What could be wrong? Is it most likely the right exhaust valve is not opening all the way? Any suggestions? Thanks Matt
