nikki
Moto Junkie
- Apr 21, 2000
- 5,802
- 1
4 weeks ago I shattered a clutch plate. Fixed her up and shattered another this past weekend. Does anyone have any ideas why this is happening? Is there something "bigger" that I might be missing? I've had this bike since new and was problem free for 16 months. Using the same oil the whole time (Castrol 10-40 I believe). All fairly new baskets too. Just wondering why - so we can fix the problem asap.
Here is all the extended info:
4 weeks ago:
Riding with 5 hour old OEM inner/outer baskets and 5 hour old fibers and steels. Can't remember if we replaced the springs or not. After about 1 hour of on/off racing that day... I shattered fiber #3 (counting #1 as the closest to the outside). Still rode the bike for another 20-40 minutes after the shattter. Didn't know that was the problem until we took off the clutch cover.
So we cleaned out the pieces from the shattered plate. Filed down the rough edges on the inner hub. The outer basket still looked good. We just replaced the broken fiber at the time. Used all of the same fibers/steels/springs. Bike worked fine for 8 more motos (about 2-3 hours).
Saturday 3-30:
Raced the bike pretty hard on and off for 40 minutes (was revving pretty high in 2nd-3rd gear - sand track :) ). Then it happened again - shattered another plate. Finished the moto and tried not to touch the clutch too much. Took off the clutch cover again to check out the damage. Shattered fiber #4 this time. Not as bad as the first shatter. This time, though, the inner hub was grooved up pretty good and the outer had a little roughness to it, too. Pressure plate (stock - 16 months old) still looks good. This time we flushed out the bike really good to get out the remaining fiber. But I still have this fear that maybe we're missing a few pieces - like maybe they're hiding out somewhere. Any good tips to get all the debris out?
My plan of action:
I'm going with a new Hinson outer basket and a new OEM inner hub and pressure plate. New fibers/steels/springs. And hope for the best.
Does anyone have any ideas why this happened twice in a month? Weak fibers? (Yamaha's do have weak clutches - for example - Hinson only makes fibers for like 3 bikes and the YZ 125 is one of them). Or maybe in the first shatter a fiber suffered a stress fracture? Or maybe there was still a little of the first plate in there to mess things up? Or the springs got hot and lost strength? Or a warped plate? Or maybe something bigger...? :think
Thank you in advance for any help/opinions!
4 weeks ago:
Saturday 3-30:
My plan of action:
