Jim Crenca
- Mar 18, 2001
- 509
- 0
Just pulled off old (thought to be original) lighting coil to install high output Electrex unit.
They sure look similar; both have .0026 wire, and measure 3 ohms when measured with a standard multi-meter.
One has a maroon insulator, the other black.
The connection was hand soldered with a heavy duty insulating sleave; while a pro job it sure doesn't look factory.
Is there a noticeable difference visual between stock & high output? Maybe I've always had the good stuff ...... :bang:
