Hi all,
My problem is slow running which is not crisp and stutters then clears it throat and flies up the top end of the rev scale.
The jets I am running is a 152 main and a 42 pilot, the needle is standard and position is in the middle on a 90 kdx200 35mm carb, float height is bang on 16mm as recommended.
A full throttle plug chop revealed jetting to be spot on.
I am also using a FMF gnarly desert pipe with a powercore 2 silencer and the airbox lid removed.
could this be a problem with the kips valves??
I have checked the valves with the exhaust front pipe off and they all move when turned by the gear on the side all though they sem a little stiff.
Any help appreciatted :bang:
