I RIDE A 1999 YZ 250 AND I JUST NOTICED THAT OIL IS SPRAYING FROM THE PIPE AND ITS SPOOGING FROM THE OIL OVER FLOW VALVE PLZ ANY ADVICE :bang: :bang: :bang: :bang:
I'm guessing that the oil overflow you mentioned is the vent tube on top of the transmission? The trans may be becoming pressurized by a blown gasket in the cases. Some oil will collect around the end of the pipe on a 2 stroke, not all of it is burned during combustion, but it is not supposed to be spraying out. Your mix ratio might be way off, I run a ratio of 40:1 in my Hondas. Is there any water mixed with the oil coming out the exhaust?
no and the oil just leaks out of the pipe i fixed the promblem i needed a pipe o ring and a head gasket so i just put new gaskests on the whole bike ty for ure help
