kawiman
60
I bought a '99 KX 250 with Race Tech suspension, weigh 170, 6' 1" tall, mostly woods ride. I would like some help setting the rebound and compression, and maybe the sag, thanks.
This is setup sheet for the suspension.
Fork setup
compression valving cL 5 cH 3
midvalve check plate mod.
oil 90mm level RRF 01
fork spring rate 0.426KG
preload 10mm
Shock setup
compression valving cL 8 cM 13 cH 99
rebound valving rL 3 rH 5
nitrogen PSI 175
shock spring rate 5.2KG
sag 95mm
