My KDX has started experiencing a problem where when you change into 2nd gear it slips back into neutral unless you physically hold the gear shifter up to give the sprocket time to engage. We disassembled the clutch and checked for debris/damage but found nada. When We went to put it back together I noticed that the 4 retaining screws that hold the clutch basket down seems to seat all the way, leaving no play in the springs whatsoever. It seems like the clutch can't seperate the wear plates unless the springs can be moved. Does anyone know if there is a specific depth to which you should seat the screws? Again, all the way down doesn't seem to let the springs do their job. I can't seem to find anything in the manuals. Anyone ever assembled a KDX clutch??
BamaKDXer
Ride till ya die!!
BamaKDXer
Ride till ya die!!
