For fun I thought I'd rebuild/restore on old bike. So I picked up an old 1978 KE175. I finally got it all together and running. I rebuilt the carbs, new rings, and top end gaskets. The bike will start on the first or second kick, and it will idle all day. In neutral, at a standstill, it will rev to redline (about 8,000rpm) at WOT. But once I'm moving, it will barely rev past 6,000rpm at WOT, it feels very sluggish, and barely picks up any speed. I'm still using the old, original plug (not sure the mileage on it), and it's getting a liitle carbon build-up. So I figure I'm a little on the rich side and I adjusted the clip on my main needle, no improvement. Should I be checking the ignition timing, or all my problems in the carb? When I rebuilt the carb, I used all the OEM jet and needle sizes. Any suggestions on what I should look for would be much appreciated. Thanks
