Ive got a 94 xr100 that Im rebuilding.
The "T" on the flywheel lines up with the V point on the case, but where does the O on the cam sprocket go? Straight up or straight down?
Thanks!
Thanks!
Can't remember if it goes up or down but, with the piston at top dead center, both lobes of the cam should be pointing down towards the piston. Then look at the O on the sprocket and center it.
