Hi, ive got a 76 CR250 that was recently just ifnshed putting back together. Before we took it apart, it ran fine, and had all of its power, but we wanted to restore it some and clean it up. We gave it a new fuel tank, cleaned carb ultrasonically, new fuel lines, new air filter, in line filter to grab any stuff from the new gas tank, and thats it. Now after starting it up again, it hesitates and has almost no power when even a small amount of throttle is applied.
The first thing I thought was that maybe it needs rejetted because of the new air filter, but air flow should not be a factor, because the people that owned the bike before me were not very tech-savvy, and didnt even have an air filter on the bike. They only rode it on asphalt roads but still.
New spark plug gapped correctly as well, but still nothing. If i turn the air mix screw on the carb all the way lean, it will run a little better but not much.
Any ideas?
Any ideas?
