Hi advice needed please!
Status
Not open for further replies.
marshy
Hi everyone, i have just bought a honda cr125 1996 model motocross bike and was hoping someone could tell me the fuel mixture ratio. 1 person told me 100ml to 5 litres and someone else told me 125ml to 5 litres. Which do i use?
Many thanks in advance.
High Lord Gomer
Poked with Sticks
Different people with different oils will range anywhere from 100ml (50:1) to 250ml (20:1). I would suggest Honda HP2 oil at 32:1, or 156ml per 5 litres.
marshy
this is whats confusing me. i've asked 3 different people an d had 3 different answers lol. I just want to know whats best 4 the bike lol
Patman
Pantless Wonder
As was pointed out...
There is no defacto standard. 32:1 will offer plenty of protection provided you use a good quality oil and fuel.
rmc_olderthandirt
Subscriber
Ask 7 more people and you will end up with a total of 10 different answers!
From the longevity of the engine point of view, more oil is better. From the environment and cost point of view, less oil is better. You will find slight variations in mix ratios based on the measuring system: i.e., in lites you would round off to 25:1 where as measuring in gallons & ounces you would end up at 24:1
Years ago the standard mix was around 24:1. With the introduction of synthetic oils the same level of lubrication could be achieved with a much less volume so the standard mix crept up to 40:1, 50:1 and even in some cases 100:1
My recommendation is to pick a mix that you are comfortable with and then stick with it. The oil doesn't really count as fuel when it is burned so changing the oil to gas mix will also change the fuel to air mix in the carburetor. Ideally, you will adjust the jetting for the oil mix you are using and then you won't want to change oil mix unless you intend to rejet the carburetor. If you are riding the bike really hard, as in racing, then you might want to run more oil, such as 25:1. If you trail ride a lot and don't push the engine hard at all then you might want to use a higher ratio, such as 50:1 so that you don't foul the plug as easily.
Rod
Status
