As you know the KYB shock on the KXF/RM-Z 250 '04 comes with only a lowspeed compression adjuster on the shock.
I like to have more ways to adjust my shock, so i like to have Hi/Lo speed adjuster. As i know from older KYB shocks with Hi/Lo, there is a second passage in the shock body (rectangular to the main cavaty where you put the comp adjuster in). Looking from the outside, i could not see any second passage on my KXF shock body.
My question :
Have you modified a KYB shock of KXF/RM-Z 250 '04 to hi/Lo speed compression ?
Will an older KYB or Showa Comp adjuster work, and if from what model or bike ?
Do you know of any other shock that will just fit (eyelet to eyelet 475 mm) ?
Thankks for your help - Hagen
My question :
