Hi,
I'm replacing the stock clutch basket with a Hinson in my 90' cr250.
The problem is that when I put all the clutch plates and discs in, the outside friction disc is not seated far enough into the basket--when the clutch is disengaged, this last plate will slip out of the fingers. Does anyone know if you're supposed to use a different washer between the inner hub and basket or something like that? The instructions that came with it don't mention anything like that. Any help/advice would be much appreciated.
Thanks,
-John
Thanks,
-John
