robwbright said:How big are you?
I'm 5'4"and the only real problem is starts in MX and slow off camber corners in the woods.
You can cut the seat foam and lower the seat height about an inch maybe even two.
You can cut the subframe and lower the seat maybe an inch.
You can have a suspension shop lower the forks and shock anywhere from an inch to four inches depending on what kind of riding you're planning on doing.
slater said:im considering a 85 but i really want a 125 so i can grow into it, i don't really want to cut foam from the seat as when i get older ill be perfect size without any height changes to the bike
