You can put the nut back on with the bolt slightly setting in the thread.You can take the zerk fitting out and spray liquid wrench and heat with torch,BE careful.Spray the ends with liquid wrench and heat with torch and try to suck the fluid in between the bolt and collar.If it start to move out spray and heat again and hit it back in and work it back and forth.
