How to adjust a flot level in PJ carb ?
helio
258
Hi guys...I am a novice on these things.
Who can please explain mel me how to adjust the float level on PJ carb(bike CR 125/98) ?
Thanks alot.
DEA
179
If you can look in the owners manual(almost any will do) it would be a lot easier to explain
"a picture's orth a thousand words"
Durt Cycler
Trial Subscriber
1,173
My service manual doesn't show how to measure the float level...So if yours don't you want to have the carb tilted so the float peice (that pushes the needle vavle) is just BARELY touching it and not compressing it. Once that is done you take a rule or measuring tool and it should be 16mm exact from where the bowl lays on to the end of the float. Adjust the float peice if needed to get exactly 16mm. I just did mine and now I hav eno gas leaking out of the lines when I barely lean my bike over.
