Zerotact
- Dec 10, 2002
- 1,001
- 0
HI,
i have read numerous posts on what springs to buy, get, and use. But I have not really found much on actually swapping the springs. Do I just onscrew to top off and pull the assembly out with the spring, remove the old spring, and put the new one in, cutting a piece of pvc pipe to make a spacer with 10mm of pre-load. And then top to oil off to 100mm below the top of the fork compressed. and the slap the asseembly back in and tighten everything up?
If this is right it sounds too easy... when i pull the assembly out there won't be any loose parts?
