1. Whtat about sleeves? I have read that putting in a sleeve will make the bike run hotter. I am putting a sleeve in Yz 125. The guy that is doing it says that new technology and what not, made better sleeves that dicipate heat better. Is this true? Should I have any worrys with the sleeve?
2. I think I seized it up becuase I was running up a big chat dump all day. About 4th WOT, then when I got to the top I would let off the gas. I have read that this shutts of the fuel/oil when you get to the top. and the piston is still moving as fast as it was. How do I stop this? This has got tobe a common probablem, becuase I know I am not the only one to run these bikes like this.
3. Once I get the cylinder back I am going to try to jet it right. It will be standard again. It has 270 main, 40 pilot and 2nd from the top needle. i have been told this bike runs great stock. Should I change the jetting back to stock and go from there?
4. Is there a chart or something on how to tell fuel ratios? I run 2.5 ounces to a gallon. Is this 32:1? How many ounces is 32:1?
