The hydro clutch makes the pull HEAVIEr on many bikes. The best and cheapest option is to get a motion pro T2 grey bale, get a motion pro cable luber and use alot of wd-40 as lube. Get a cr lever and perch
(better leverage ratio) and grease, clean and lube it often. I do it every ride and sometimes after I crash!!! Really, most heavy and inconsistent pulls are do to a lack of clutch maitenence. Take some advil too before you ride. It thins the blood out and really relievs the cramps that you are encountering when you ride.
