my bike doesnt want to idle, it runs great everything is fine but when i let it idle it just dies after a couple seconds, wont stay running, what could it be?
mine dont idle too but it need to be adjusted, just turn the idle screw on the carb so it can idle(i dont know for a cr250).
On my manual, it say to set the screw to the lowest idle possible when the engine is at normal temperature(warm).. so it should idle.
idle is not needed to ride/race, but on a stop or on trail while waiting friend that are far behind or to smoke its usefull to let it idle in some case instead to hold the throttle or kickstart again.
