canadian-dirtbik3r
- Jun 12, 2005
- 229
- 0
I have found out acouple ways to paint my tank and i want to no what would get the best results and if you would like to describe how your paintjob turned out that would be great. If i miss anything feel free to fill in. Right now i have my tank stripped of all paint and cleaned with comet soap and a degreaser and sanded with 150 grit. ok the first painting method is using fusion kypton. So ive heard before painting with fusion paint i should use acetone on the tank. Is this correct? So say i use acetone and then spray 4-5 coats and let dry for what? a week or even more? The next way is using plastic adhesive promoter with a urathane paint. Spray the tank with the adhesive let it sit for 5 mins then apply the urathane paint with 4-5 coats. And then theres vinyl dye but ive read that it doesnt turn out to well. So i would like to hear your 2 cents. And add anything that helps. Thanks alot i would like to get started painting tomoro.
