Yes with the mods you described your bike will increase in power...ONLY if you go through the time to get the bike properly. Most aftermarket exhaust companies give you a guideline of what to change your jets to. Start with those as a baseline and test ride it to make sure everything is running good. Pipes, reeds, and silencers are all dandy but if you're bike isn't getting the correct amount of fuel and air mixture into the engine, you won't notice a big difference.
As for the new triple clamps, it's not going to turn you into Ricky Carmichael but with some new bars and rubber mounts you may feel less fatigued after a few laps. If the handling of the bike is still not to your liking, you may look into getting your suspension done.
