Re: 03 KDX 200 w/ -35 pipe, stock gearing / 150 miles from the gulf coast at 500 feet elevation
I switched from a 160 main jet to a 152 and after a second WOT check, it was white hot. I went to a 155 (middle clip) and it looks very hot and dry, but has light-med brown porcelain on the inside around the plug gap after the WOT check. Both ways run very well and the transition from slow to fast is super smooth with the 152 and the 155 main.
I checked my 48 pilot jet and I could still get an RPM increase after 6 full turns out. Based on Canadian Dave's excellent carb tuning site, it appeared that I needed to drop down. I switched to a 45 and I can get an increase in RPMs up to 3 1/2 full turns out and then it seems to drop off. My concern here is that at idle, the plug looks just like it does after a WOT (super dry and light-med brown), anywhere from 1 1/2 to 3 turns out on the air screw.
The bike is running great, but I have a feeling it's a little lean, even though it should not be. One thing that does sound different is when I let off of the gas. It sounds like a "funny car" with a big cam. It has that "off the gas lopeing sound".
It may be perfect, but the always super dry hot looking med. brown color from idle to WOT makes me want to run this by the group and get an opinion.
Thanks for your help
JCW
JCW
