I removed the tube for the first time from my 01CR250 and I noticed that there was a nut on the valve stem, but it was on the inside of the wheel. On the outside there is just a rubber grommet shaped to fit the curve of the rim. I have read on the web where that nut should be on the outside of the rim so that it holds the valve stem in place. Did Honda mess up or is the nut not really needed? Should I just reinstall the tube as it was or should I remove the nut from the valve stem and reinstall it once I push the valve stem through the wheel?
