jmonintwo said:So I had a little play in the rear wheel. I took it off, took off the caps and grease seals and there they were....worn bearings. I could put my finger in the hole and try to spin them and could feel the grit and wear in them. Took the forum's advice, soaked them in WD for a while, took my time and slowly and evenly heated the hub with a propane torch, stick a large screwdriver though, lightly tapped with a 2lb sledge and it only took about 10 gentle licks for the old ones to pop right out! Froze the new bearing while I slowly heated the hub again and the new bearings dropped right in a few gentle taps. Put it all back together and I'm off. Thanks KDX Forum![/QUO
tighten up your spokes while you are changing the bearings :cool:
