I'm looking for 2 peices of info. Bike smokes more than it should yet runs well. Jetting recomendations and thoughts on oil in the airbox.
1. Jetting - 03 220, stock carb, air box lid removed, gnarly rev pipe, turbine core spark arrestor (recently re-packed) wesco piston (fresh), ported (nothing radical just cleaned), milled head, torque ring, boysen dual stage reeds, ride at 8000 ft approx 70 degrees, low humidity, silkoline comp 2 premix 40:1 current jetting 40 pilot, 135 main, needle one step leaner (clip moved up one slot). Plug is a bit black an sooty. The bike has a small bog off the bottom but runs fairly well but smokes more than it should? Appreciate any Ideas.
2. There is continually what smells like premix pooled in the airbox on the carb side of the airfilter. We've tried no greese no oil on the filter ( in a clean environment) and it still occurs? Crank seals have been replaced. I've been told it coud just be blow back through the carb but it sounds fishy. Thus the question on jetting. Any thoughts would be welcome.
Thanks in advance for your thoughts !!!!!!!!!!!!!!!!!!!!
