i have an 01 rm and still having jetting problems. i havent had enough time on the bike to figure it out. please help.
the problem is when i am at 3/4 to full throttle there is a noticable gurgle that is quite bad. i am running an sst combo, everything else is stock.
i have jetted down to a 158 but it was 50 derees out.no power to lean.since then have run a 162 main but gurgle is still apparent.
could this be a needle problem? or a power jet issue?
i have also been told to lean out the pilot jet circuit.but i thought that affected 1/8 to 1/4 throtle.
the arena cross series starts here in mid january, so the temp will be quite low. 35 to 50 degrees inside.
how does a power jet system actually work?
particulars elevation 750 ft above sea level
temp 35 to 50 deg.
mix 32:1 silkolene 92 oct.
thanks
temp 35 to 50 deg.
thanks
