Noob question....here goes...
My bikes doesn't have spark (79' YZ250). A friend told me to pick up an ohms meter or multimeter so I can test the parts so I did just that. This is the one I bought (hoping this might help): http://www.sears.com/sr/javasr/prod...=Automotive+Testing+Equipment&pid=00920926000
The only problem is im not sure how to use it. I read the directions but they don't really help me that much because ive never used one before. So, here is my question: How do I use it to test my stator, cdi, and coil?
Here is what I am looking for:
-What setting should my multimeter be set on?
-What wires do I attach the multimeter to and where on those wires? (and what wires they are..ex: ground, etc)
-And what do the results/numbers on the screen mean?
If this helps, here is what the wiring looks like starting with the stator:
Stator: It has 3 wires coming out:
1) White w/ red stripe
2) Red
3) Brown
Those wires go to into the CDI
Then there are 3 wires that come out of the CDI box:
1) Black w/ white stripe
2) Black
3) Orange
There's also Black w/ Red Stripe wire - This one comes out but then loops and goes back in where it came from.
Those three wires go to the coil. The black wire and black w/ white stripe wire from the cdi go into a connector that gets screwed down (kind of like a washer) under one of the mounting screws for the coil. The orange wire from the CDI is connected to a black wire that goes directly into the coil.
Then there's the spark plug wire that comes out of the coil.
So...where do I start?
if anyone wants, i can take pictures of the parts too...in case it helps.
2) Red
3) Brown
2) Black
3) Orange
