Just got 4 acres. Jump building question...
JD-250
47
I just recently bought 4 acres of land which most of it will
probably be a motocross track sooner or later. There is a old school bus on the property and instead of getting rid of it, I was thinking it would work as a base for a big table top. Do you think this would work? Or would it be too tall for a jump after I put dirt over it? Also, if anyone has any advice on how to build the track fairly cheap or what equipment I should rent so I can do it myself. Thanks.
KX02
781
I would use the school bus for a tunnel under the jump! You probably should rent a Bobcat to build up the jumps and move dirt around.
