Welp,I finally finished. Heres what I did.New sprockets,chain,rear suspension bearings, seals,linkage,nuts,bolts,shock bearings, rear wheel bearings,rear wheel brake rotor,pads,oversized gas tank,.42 fredette fork springs,fork pistons,seals,fresh fork fluid,new neck bearings,races and seals. Rejetted from stock 160 main to 152. and from stock 48 pilot to a 45 pilot.Also set my static sag to 1 inch. Im sure this put my sag to to around 100mm as the adjustments were very close. Also new front wheel bearings, and the throttle slide spring which was worn flat on one side and broke on removal. Throw in some new shrouds and fresh decals from all the stuff I bought, and I think thats eveything.
Saturdays ride was typical florida trail and the bike was just awesome. The most noticable change was the throttle response at low and high rpm :ohmy: Never been that strong before. Blasting through palmettos was much more controlable and smooth. The tight stuff was much easier w/new stem bearings. And lastly, I was now skipping over those whoops that ate me up pre overhaul. Thanks everyone for good advice. It really helped. :cool:
