When we put the clutch/right engine cover on the '92 KDX 200,
the alignment of the kickshaft seems to change resulting in kicking
thru without the clutch basket being engaged. Ratchet and return works without the cover on. Appears to be no broken or missing
components. There is wobble of the kick gear on the shaft. Don't know if adding add'l shim washers, more than the .020" thickness used will help, or what the real problem is. Solutions to the mystery?
