My 2004 KDX220R has finally sprung its first oil leak. After I ride and store it, It leaks maybe a tablespoon out of the drain plug. I change the oil every third ride. I have not over tightened it to my knowledge. There is no trash on the threads of the bolt or the case, and the threads look very good on both. The case and the back of the bolt look in good shape and have no dings or anything. Any suggestions?
Second question on fork seals, I have one leaking and have bought the seals and oil to replace them, I did a quick search on seal replacement and did not find much, maybe I am searching wrong because I have seen many many post in the past on it. I know there may be some speciality tools required that I will buy if needed. I am looking for helpfull information so I do not create a nightmare Thank you for any help. :yeehaw:
