i just bought a 01 kawasaki kdx200 and there is a little surface rust on the frame. i know i have to sand it but what color is the frame and what type of paint should i use this is more of a cosmetic then any big problem
The stock color is Kawasaki Green. I used PJ1 paint for the touch up areas on my 2001. Works great, and the color match was perfect! Most of your local bike shops have it. So does rockymountain.com
u also have a 2001. well mine has a procircuit pipe and silencer , uni filter, carbon tech low tension reeds and frp .42 fork springs any other good modifications u could recomend?do u jump with urs?how much do u weigh if u jump i weigh 190 and i want to jump is the stock rear suspension good enough for me? and last question where is the compression clicker on the rear suspension i no its kinda dumb askin this question but i dont want to turn the wrong screws
Yep, Your ahead of me on a few mods. I have a FMF -35 pipe (narly woods) and the Turbine Core II silencer.
I just bought this bike in Feb. I had a 92 before this one. I plan to do the front springs as well.
The rear spring is perfect for your weight. It will hold up to a 210lb rider. I don't do any jumping with mine other than the occasional whoop-de-do's. I do a lot of trail riding.
I would recommend the airbox modification if you hav'nt already. That woke mine up with the pipe I have. Although it does... as quoted before "sound like your sitting on a duck" when you hit the gas. It's a little louder but worth it.
And for your last question the compression damping is on the gas reservoir on the right side of your bike up near the seat/number plate area. Then to adjust Rebound its on the bottom of the shock.
I would also recommend checking out this site for lots of other mods for your KDX http://www.dirtrider.net/justkdx/ ..... then click on tech tips
