TimW
16
I need some advice. I have a 1990 KDX 200 and I have replaced the old dot3 fluid with a dot4 fluid as suggested by Fredette. I have bled all of the air bubbles that I can see and kept bleeding, bleeding, and bleeding! I can't get any pressure back to the brake lever and have no front brakes. Help!!!
Frustrated...
TimW
dirt bike dave
5,348
When I bought my '90 used, it had a very persistant bubble that would not bleed out. Finally, I took the hose, caliper and master cylinder off the bike and hung it up on the wall with the caliper up. I let it hang overnight, and tapped the brake line with a screwdriver handle from time to time to knock any bubbles loose.
Next day, laid the hose on the ground with the caliper elevated, and bled it off the bike. No more bubble! It was a PITA, but I wish I hadn't wasted so much time and fluid bleeding it the normal (and ineffective) way.
