- Jan 27, 2000
- 6,961
- 45
motopsycho87 said:, so I really do apologise for adding it in there!
No worries. :cool:
Having been in this business for a long time and having worked at the corporate level with engineers, I have learned that everything is not set in stone. What works on paper doesn't always work on the racetrack or in real life. It's best to keep an open mind.
IMO, making your own gaskets is not the way to go. There are times when you have to make a gasket. Doing a repair the night before a race or a ride and you have no gaskets. Then, you may have to make a gasket. Then, and only then should you make your own gaskets. Like others have pointed out, thickness is important. Also, OEM gaskets have sealant in certain critical areas that can leak without the proper sealant. There are also critical holes in certain gaskets that have to be a certain size. Making new gaskets without these holes or with the wrong size holes can damage your engine. Annealing a copper head gasket can only be done a few times before you cook all of the oxygen out of the copper and it becomes brittle. Normally, annealing a copper gasket does not change it's thickness but, re-using the same gasket over and over can.
One of the things we do in my shop is restore old British bikes. Many times gaskets are not available for these bikes and then we have to make gaskets or anneal old ones. But, if the gaskets are available, we buy new ones.
IMO, it's a good idea to buy a gasket set for your bike before you need it and keep it handy for emergency repairs. There are a lot of things on your bike you can save money on but, gaskets are not one of them. Buy a couple extra head and base gaskets too just to keep in stock.
BTW. The copper spray is called 'Copper-Coat' and is available at most auto parts stores. Spray a couple of light, fog coats on each side then apply one heavy, wet coat just before bolting on the head.
Just my $ .02 U.S. or .029 Pounds Sterling. ;)
