I do not have the kdx regulator and bought a moose racing one, installed it as per directions and now my kill switch doesn't work.
The regulator has 2 wires, one brown grounded to the frame and one yellow. The yellow wire is connected to the yellow power wire comming from the engine and the headlight wire is tapped into it. The negative wire for headlight is grounded to the tripple clamp.
If i disconnect the yellow wire my kill switch works.
The headlight works fine.
The kill switch does not work when the lights are on or off
Any ideas?
Any ideas?
