Rob84KDX200
- Jan 31, 2004
- 64
- 0
i've been recently completing the wiring on my '84 kdx200 (aus B1 version), all done with great success so far... i've now come to installing the rear brake light switch. i've purchased an oem switch, it's now installed to the frame as per factory default location. what spring setup is used to connect the switch to the rear brake pedal? i've had no luck on this, as the stupid swingarm bolt head is in the way! and the kickstarter would definitely 'crunch' any spring that'd be nearby... any thoughts/recommendations/advice/HELP!!! on this topic? please keep in mind that this is for an '84 model with a rear 'drum brake' setup, so no plumbing to contend with.
thanks in advance.
Rob C.
http://www.labyrinth.net.au/~rcacic/kdx200
thanks in advance.
Rob C.
