I bought a used '97 KDX220 a few months ago. Here's what it has.
FMF fatty pipe w/turbine core muffler
Boyseen power core w/carbon reeds
1mm over Wiesco piston
Eric Gore porting
145main
42 pilot
needle clip at 2 from top
Using Motul 800T premix @ 40:1
Here's the problem.
When I first bought the bike, it wouldn't idle w/o choke. Idle screw turned all the way in and won't idle. Also, just running it in 1-2nd gear at 1/4 throttle it feels/sounds like its on choke. Very rough sound. Also, there is oil just dripping out of the muffler. At first I thought the power valves were installed wrong, since the previous owner (2nd owner) wasn't to mechanical and had reinstalled the cyl/piston combo. Power valves checked out ok.
After compete carb clean and everything else checking out fine, I dropped the pilot jet to a 40. Not much difference...still no idle. Next I dropped it to a 38. Idles fine..a bit rough, but idles. What I can't figure out is why it still sounds like its on choke at partial throttle openings and why oil continues to drip out of the pipe. I've even taken apart the muffler, completely cleaned it out and repacked it.
The bike runs fine when ridden hard and really screams on top. However the transition from low speed to high speed is not as smooth as other 2strokes I've ridden.
I would appreciate any feedback and possibly solutions to this nagging problem. Someone also told me to check for crankseal leak as I am possibly pulling oil from the crankcase into the cyl ? I have not leak tested it yet, but thought if that was the case, I would be fouling plugs ?
Thanks,
Lee
Eric Gore porting
145main
42 pilot
Here's the problem.
Thanks,
Lee
