Though I've never tried it, a local gear head uses a dab of RTV on the last few threads on low torque bolts (like street bike body work). The bolts will vibrate loose but will not fall out.
Depends on what the screw/bolt is inserted into. Any screw/bolt that inserts into a nut, I replace the nut with a Nylock nut. The Nylock nuts have a plastic insert that really cinches the screw/bolt and prevents them from vibrating loose. Nylock nuts should have won the Nobel peace prize :worship: !!!
I use to have a big problem with the screws/bolts from the side panels and pipe mounts vibrating loose. Lock washers fix these problems rather well.
