Took the top end apart today, looked good but still puting a Weisco in because It's a 220. Took a look at the powervalves and they all looked a bit gooey but not too bad. Worked but seemed a little gummed up so I cleaned them with solvents (brake cleaner, gas and kerosene, tooth brush and small wire brush) , but did not take them completely apart. I oiled them with MX 2T after gettin them cleaned and they worked quite good and freely. I made sure everything was opening and closing and properly timed by matching the lines between the two knotched gear teeth on the side valves. Now here's the question.
When putting them back do they go together with the valves open or closed when I attach the shaft? I assume that they are open when at low RPM's and close when on high RPMs? Is that right?
BTW, a spoke wrench works great to hold the shaft while loosening the nut.
It was nice to have all this information prior to getting into the job as I was aware of the shaft being left threaded and the web page by Brian was helpful but I still was not sure hoe to take them all the way apart but they didn't appear to need it. I have been using Mobil 1 MX 2T for quite a while, but started out using Golden Spectro for about 3 months.
