HAS ANYONE HAD PROBLEMS WITH REAR HUBS IN LC50 PULLING
SPOKES OUT. THIS IS SECOND ONE IN THREE MONTHS LOOKING
FOR STRAIGHT PULL HUB.OR AFTERMARKET VERSION.
instead of spending big dollars on aftermarket hubs, rims and heavy duty spokes, your problems can be solved with a properly set up shock i.e. one thats not bottoming out. when the shock bottoms out the force of the landing is transmitted through the rear wheel, shock and frame. i would check your frame for cracks and check with your dealer about the optional WP rear shock.if your child is very aggresive then the WP is the way to go. properly set up, this shock will solve your problems.
THANKS FOR YOU REPLY BUT WE CHANGED TO A KERNUT SHOCK AND HAD
THE FRONT FORKS SPRING AND VALVED FOR HIS WEIGHT I CHECKED FOR
SUSPENSION BOTTOMING TO BUT IT IS STILL BREAKING HUB WITH NEW
SUSPENSION THANK YOU
