Cheater
129
I know you trail riders love your ktms, so I figured I sould ask you. My friends and I were riding last weekend and my friends 05 525sx just stopped. he was riding in second gear at a good rpm, no good reason to stall. He tried kicking the bike over it wouldn't do anything. We couldn't even pull start it. So we brought it home and changed the plug, and checked the coil. But it wouldn't spark. There was alot of water where we were riding, is it possible for water to get somewhere it shouldn't be? I would appreciate any suggestions, any trouble shooting we can do.
JMD
1,402
When a bike is running at a good rpm and dies like somebody threw a switch, it means something is badly wrong. As an old mechanic once told me, an internal combustion engine runs on air, fuel, and fire, plus compression. I've never seen a bike stop running because of air supply, so it's not that. And they don't stop suddenly from a fuel failure; more likely, it would have done a panic-rev as the fuel supply dried up. So it's not fuel. That leaves spark and compression, and either one will cause a sudden failure. Is the bike excessively easy to kick over? If so, you've lost compression and will have to rebuild the top end or the valves. If compression seems good, pull the plug out and attach the lead wire. Ground the plug on the engine head and kick it over in the dark. You should see a hot spark. If no spark, you need to test the stator, the pulse pickup, and the coil. One of those is probably bad; that happens to KTMs sometimes. Hint: check your spark plug lead wire first, though, to make sure it's not broken. That's a cheap fix.
Cheater
129
It kicks over like normal, we check the spark and didn't see anything. we had the coil tested, it was good. Where is the stator, and pulse pickup, and how do we check these? The bike is an 05' and it probaly has about eight hours on the bike. Isn't kinda early to be having these types of probelms? I have a yamaha that has been riden twice as hard and double the hours, and I have had no problems. Starts first kick every time. :ride:
YZMAN400
2,491
Check all your electrical connections and make sure there is no dirt in any of them. That would be my 1st idea.
Maybe check the kill switch to make sure its not killing the motor ie grounding out the ignition.
From there its on to the CDI and stator. The stator is inside the flywheel inside the motor. But you should be able to test that via the leads coming out of the motor. IF you know someone else that has the same bike you can compare stator output readings to see if you have a bad stator.
Cheater
129
We jumped out the kill switch, and had the coil checked at the ktm dealer. I will check the stator, but it being in the engine it seems like it would be well protected and a little soon to be worn out?
Uchytil
814
9
Have you pulled the stator cover off yet and checked for water, loose wires? Did you check the primary and secondary sides of the coil? Not sure but is there a resistor in the plug wire cap? Check that if so. Getting a book may help with your troubleshooting. If it gets deep you'll need to know which leads to check the pulser coil, CDI, charge coil, etc. You may only be able to check resistance readings unless you vae a multimeter with peak V output. I'm just guessing since I don't work on katoomers.
TCTrailrider
980
Check the plug wire connection at the plug cap. The wire is pushed into the cap (not glued). Very easy to loose that connection. Check both ends.
